Re: Farmall 400 replacing crankshaft walkthrough
Posted by truckerlary on March 14, 2012 at 18:44:01 from (12.19.152.194):
In Reply to: Farmall 400 replacing crankshaft walkthrough posted by Farmall200 on March 14, 2012 at 18:36:05:
It depends on which journal has the spun bearing. If it is a rod journal you will have to split the tractor. If it is a main journal you'll have to pull the engine as it will have to be line bored.
