Distillate fuel requires less refining then gasoline or even kerosene for that matter. Since it is cheaper to refine it was less to buy. This was the advantage to this the down side was lower power out put due to the low compression of a distillate burning engine. Example of this would be the Farmall M you mention they have around 34/35hp ias a distillate and 39/40 hp as a high compression gas. If the compression of a distillate is too high generally over 4 to 4.5 to 1 it will have a tendency to knock. Another factor to consider when burning distillate is that it does not fully burn in the chamber and can dilute the crank case oil. You would back off the top petcock on the oil pan everyday and drain off the un-burned fuel. There is a ton more info out there on this just google it and im sure you can find out more facts.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
