yet one more A oil seal question
Posted by charlie M on March 16, 2012 at 16:06:58 from (74.34.216.81):
Hi guys - I've been asking a few questions concerning dismantling the rear end of my A to change oil seals and have one more question. I have the whole right side apart except removing the final drive from the housing. I have all the bolts out on both ends. Should I be able to drive the shaft from the inside bearing to get the assembly out? I know once out I'll have to have the outside bearing pressed off and can get that done at work. I can't get the inside one to come out of the bearing. Any tricks or am I missing something?
