660 injection pump
Posted by Baler dan on March 18, 2012 at 23:41:21 from (64.37.24.201):
My 660 Has a miss on number 2, I swapped injectors with number one and the miss can still be traced to 2. When I crack the line on two the blue puffs go away but the miss is there of course. Tighten the line back still misses and smoke appears again. Compression is same as others and changing injectors doesn"t move the problem. Would I be right in thinking that 2 delivery is bad on pump. Thanks
