Re: rebuilding a f 20 oil pump
Posted by Centex Farmall on March 19, 2012 at 19:17:40 from (166.147.69.192):
In Reply to: rebuilding a f 20 oil pump posted by SDE on March 19, 2012 at 15:10:28:
Sometimes you have to be creative to get the old stuff to run. Mix and match as necessary to make a complete pump. Just check the clearance between the end of the gears and the housing. You may have to sand the end of the housing or gears to get .002 or so.
