Locating the probe on the inlet side of the turbo gives you the most useful data. After all it's the exhaust turbine inlet temperature you want to limit so it does not damage the turbine.
Temperature on the outlet side of the turbine will always be lower than the inlet. So it cannot directly indicate what's happening at the hottest part of the turbine.
Therefore locating the probe on the inlet side is preferred. HOWEVER should a probe there break off, it will be ingested into the turbine with disastrous consequences. But if a probe breaks on the outlet side of the turbine it will simply be blown out the stack, leaving the turbine intact.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
