You can change out that seal with the belly pump still in the tractor, but it is so much easier if the pump is removed. Well worth your time to do it.
Farmall Hs are rather cold blooded, and the hesitation MIGHT be just because the engine is not warmed up enough. If that is not the case, then I can recommend making sure the carburetor high speed idle adjustment screw is a minimum of 3 turns out, and if that does not help, then there is still some crud hiding deep down in the carburetor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
