H idle to wide open throttle and belly pump issue
Posted by gary in neb. on March 20, 2012 at 06:17:34 from (24.116.17.253):
Hi all, got an H i'm working on after the owner could not get it to run. put gas in, and wow, it runs, BUT when going from idle to WOT you have to go pretty slow or it will die, like lack of fuel maybe? or is that a timing issue. took carb apart, cleaned it up. idles great, WOT great, just going from one to the other.
also noticed the rear seal of the belly pump, where the trans shaft comes through is leaking. can i change that in the tractor by removing the coupler?
thanks
Gary
