Re: H idle to wide open throttle and belly pump issue
Posted by rustyfarmall on March 20, 2012 at 08:25:20 from (216.248.71.224):
In Reply to: H idle to wide open throttle and belly pump issue posted by david G on March 20, 2012 at 08:00:04:
I made an adapter that let me use an air impact to remove the coupler shaft. Might be another way, but the impact seemed to be the quickest solution.
