Re: H idle to wide open throttle and belly pump issue
Posted by david G on March 20, 2012 at 08:00:04 from (204.29.138.33):
In Reply to: H idle to wide open throttle and belly pump issue posted by gary in neb. on March 20, 2012 at 06:17:34:
You can change that seal, but need a way of holding the shaft from turning while loosening the adapter for the coupler. I do not know how, so let me know if you get it.
The pump is HEAVY, put a jack under it and get help.
