Re: H idle to wide open throttle and belly pump issue
Posted by rustyfarmall on March 20, 2012 at 10:44:06 from (216.248.71.224):
In Reply to: H idle to wide open throttle and belly pump issue posted by kris Jensen on March 20, 2012 at 09:09:53:
A dirty, sticky governor would exhibit totally different symptoms. Don't think the governor has anything to do with it.
