Re: H idle to wide open throttle and belly pump issue
Posted by kris Jensen on March 20, 2012 at 09:09:53 from (70.66.53.35):
In Reply to: H idle to wide open throttle and belly pump issue posted by gary in neb. on March 20, 2012 at 06:17:34:
If your carb is really clean and jets are adjusted, I would make sure your governor is also really clean, and the weights are not sticking. you could have an accumulation of old oil turned to dry gunk in the governor. before tearing it apart try some penetrating oil and degreaser on the shafts.
