Battery Charge
Posted by Cedric on March 21, 2012 at 01:41:08 from (210.54.200.210):
Which is the more accurate method of determining the state of charge of a battery - using a hydrometer or a volt meter across the terminals.
I have just bought a new battery and before installing decided to check if it was fully charged. Readings from two different hydrometers showed that it was only half charged. Took it back to the supplier for them to check. They put a volt meter across the terminals and got a reading of 6.2 volts and said that the battery was fully charged. I am not convinced.
Your comments will be much appreciated.
Sid.
