Re: Battery Charge
Posted by jeffcat on March 21, 2012 at 15:08:14 from (66.19.243.151):
In Reply to: Battery Charge posted by Cedric on March 21, 2012 at 01:41:08:
Just want to throw in a few more key strokes worth. Harbor Freght has those load meters for about $10to15 dollars on special. They are the best way to tell what is what with a battery. They check voltage and amps "load" all at once. I let my unit test "COOK" for about 30 seconds. If it still in the green zone you have a good HOT battery. These will also check your charging system too. Just flip the swich and your amp gauge will almost peg and the motor will load down. Now just remember my unit is the 50Amp unit and the newer ones are 100 Amp. I use my 50 maybe ten or twelve times a year and it is fantastic. I also have an old round face unit from the late 50s and it is also 50 Amp. Hope I helped. Jeffcat
