Re: F30 Front Wheel seal
Posted by ForeverRed on March 22, 2012 at 06:05:58 from (209.117.133.38):
In Reply to: Re: F30 Front Wheel seal posted by SB in IN on March 21, 2012 at 15:06:54:
OK, well that is what I am used to doing but I had to use a bearing seperator and puller to get the inner bearing off. Even after I polished the spindle the bearing has to be driven on which is why I made the comments I did. This fit works fine for the original set up as the seal is fit over the spindle, then the bearing and finially the hub. I guess I will need to keep working the spindle until I get a nice snug slip fit to the inner bearing. The seal lip size looks to be 1.75" (spindle OD) and the hub ID is 3.75". Thanks again for all your help.
