Re: 4 Bar Side Delivery Rake question
Posted by old on March 22, 2012 at 08:34:15 from (4.245.14.243):
In Reply to: Re: 4 Bar Side Delivery Rake question posted by JRSutton on March 22, 2012 at 08:25:49:
The part that is common to have break is inside and is the slide gear that has a Z sort of look to one end of it that is the ractket (sp) part and they like to break in 2 since they have a 1 inch or bigger hole down the center of them. It is the gear that you shift in and out to put the rig in gear. I use the one I have for well over a decade and pulled it behind a B
