H radiator springs
Posted by Senator on March 22, 2012 at 19:17:28 from (72.37.249.84):
What purpose did the springs on the radiator mounting studs serve? I am assuming they offered some flexibility if the frame moved around a little bit so the studs did not rip out of the bottom of the radiator.
I'm asking because after replacing the original (wore out) radiator with an aftermarket copy I just can't get my hand in there to compress the spring enough to get the nut started. After a couple hours trying with lots of frustration, I am considering just using a washer and nylock nut without the spring (not too tight).
The aftermarket radiator does not have the mounting studs brazed into the bottom of the radiator as in the original, but are welded to a piece of heavy sheetmetal running underneath the radiator core. So I guess if there was some flexing the sheetmetal would flex and even if the stud welds broke eventually it would not damage the core.
Am I thinking right, or should I spend more time trying to get the springs on?
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
