Re: Unsticking fuel lines from flare nuts on D282
Posted by rustred on March 22, 2012 at 19:31:08 from (72.172.100.113):
In Reply to: Unsticking fuel lines from flare nuts on D282 posted by GR Gold on March 22, 2012 at 19:17:10:
i have run into this also and have used a small vise grip to hold the line and work the nut loose.and spray it with lube. be careful dont want to colapse the line.all depends on how siezed the nut is though. heat should work.
