Unsticking fuel lines from flare nuts on D282
Posted by GR Gold on March 22, 2012 at 19:17:10 from (67.141.74.111):
I want to try and bleed the lines on this engine. When I turn the flare nuts, some of the lines try and twist with the nuts. Should I try and heat them up a bit with a torch and let them cool? What is the best way to do this? Any advice is appreciated!
