1954 Super C
Posted by J.D.HEICHEL on March 23, 2012 at 21:36:22 from (67.235.0.138):
Well i spent all winter finishing up my Super C.I tried to start it after an engine rebuild and it didnt start. The 2 problems i found so far is -- I have gas dumping from the choke lever,which tells me the float and the new rubber tipped valve isnt shutting off the gas flow.Problem 2 as soon as i pull the switch out to start it the ammeter gauge shows discharge,but only a couple needle widths to the left. I did polarize the generator. It has a Carter carb. I think the switch is bad.
