Re: 1954 Super C
Posted by El Toro on March 24, 2012 at 04:40:45 from (108.3.225.57):
In Reply to: 1954 Super C posted by J.D.HEICHEL on March 23, 2012 at 21:36:22:
If you pulled the distributor your distrubutor may not be in time with No1 piston. Remove the sparkplug near the radiator and hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure against your thumb. Then drop a long plastic straw on top of the piston then have the helper to keep slowly cranking while you watch the straw rise. When it quits rising your No1 piston should be at TDC on the compression stroke. Remove the cap and see where your rotor is pointing. Should be pointing to the No1 plug tower. If the rotor is off you need to pull the distrubutor and rotate the rotor so its points to the No1 plug tower which is about 1 o'clock and then reinstall it. Hal
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
