Re: Unsticking fuel lines from flare nuts on D282
Posted by ejr-Ia. on March 24, 2012 at 09:30:59 from (204.11.182.30):
In Reply to: Unsticking fuel lines from flare nuts on D282 posted by GR Gold on March 22, 2012 at 19:17:10:
Did this many times soak with good penetrate let it work in around where the line goes in the nut.With the 3/4 wrench you will be useing I tap the nuts and lines,soak some more and tap.Then being carefull try breaking the nut loose if it does squirt some more penetrate and use the wrench back and forth as you takeing it off
