Posted by jdjack on March 24, 2012 at 18:59:25 from (174.124.99.68):
I am working on my fathers farmall B. With the throttle level all the way back in idles slowly and sometimes will die. Then if the throttle is moved at all foward, it speeds up alot and while level is being moved it doesn't change rpm until it gets to about 3/4 and then rpm increases. The hole in the lever (connected to the governor) on the left side that connects to the carb throttle plate is worn out and has some slop. On the right side, the shaft that goes from the throttle shaft to the governor, has 2 springs by the gov, the one is the front doesn't look right, short and big the one in back is long and small. Can the springs, and lever on the left side still be ordered?
can somebody post some instruction on how to adjust the linkages on these? It has a new carb, but problem was their before it was replaced. We have another on that runs and idles great and increase speed as you increase throttle.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
