Re: farmall B throttle and governor adjustemnts
Posted by gene bender on March 24, 2012 at 19:04:32 from (207.177.56.105):
In Reply to: farmall B throttle and governor adjustemnts posted by jdjack on March 24, 2012 at 18:59:25:
You need to set the linkage going to the carb. With engine off remove the pin from the clevis going to the carb. Now open the throttle adjust the clevis holding the carb open till the pin goes in. Your input lever on the gov needs to not have any slop where the lever can wiggle around with pressure. That input shaft can be rebushed then you will have good throttle response.
