400 gasser cranking problem
Posted by JGH on March 25, 2012 at 20:09:49 from (68.185.134.210):
I bought a 400 gas a couple of weeks from an Aumann on line auction, first time I ever bought a tractor sight unseen. When I picked the tractor up it would not start and it appeared that it may have a had a ground problem. After getting it home and wking on it I found burnt wires, no problem I just rewired it, had the GEN & starter tested (they were both wking correctly). Went to start it today and the same problem, turn the key and the starter would stall. Recked ever thing, cked good. Don't know why but I pulled the T/A to the low side tried it again & tractor started right UP, never ran into this kind of problem before. Anyone got any ideas what problems I have ?????? Note: Aumann folks pulled off the the tractor at the auction sight, I drove it before loading it, tractor ran ok, T/A wked as it should,no slipage, no unusal noises all running cks were good.
JG
