Re: 400 gasser cranking problem
Posted by Fullers Farmalls on March 25, 2012 at 21:46:11 from (24.239.77.45):
In Reply to: 400 gasser cranking problem posted by JGH on March 25, 2012 at 20:09:49:
Is it 6 or 12 volt? I'm guessing 6 b/c of the genny being on it. Did your wires from the battery to the starter post then to the starter get hot? They need to be 00 gauge cable. Well a little smaller is ok. Also check that the starter has clean contact where it mounts. No rust or paint. Or if you can mount the ground wire from the battery to the starter post and see if that helps. If its burning the wiring to the lights and other wires I hope others will chime in. I'm not an expert but thats a place to start.
