Re: Re: Re: Farmall H runs a while then quits
Posted by Andy Martin on September 17, 2000 at 20:39:33 from (38.31.75.109):
In Reply to: Re: Re: Farmall H runs a while then quits posted by Paul on September 17, 2000 at 20:31:29:
No, with the tube plugged the level can't move unless you get the air in to move just enough to show the true level.
Opening the drain is a little different than using a tube. With the drain open some gas will always run out and air will replace it. But I've never personally used a tube that way.
Go ahead and pull the carb bottom. It is easy and good practice. Don't drop the venturi on a hard surface. It is in the carb throat and sometimes falls out after disassembly. There will be something to clean out for your effort.
Post A Followup
: Re: Re: Re: Re: Farmall H runs a while then quits
