Farmall 450 Gas Throttle questions
Posted by Tony_Idaho on March 26, 2012 at 14:42:34 from (137.201.242.130):
Hello,
I was hoping someone could help me out with how fast my tractor should be running. I just installed a new tachometer, so I could see what my PTO was running at. When I have the throttle lever in the RED position, the PTO is not even close to the 540 RPM I need. Then I move the throttle below the base the Tachometer reads that the PTO is very close to the 540 RPM ( ~530).
Seems like this is not right. I would ASSUME that the RED lever is really all you would want to go to. But I have been incorrect before...
Does something need adjusting, governor??
Thanks
Tony third party image
