Re: Farmall 450 Gas Throttle questions
Posted by Janicholson on March 26, 2012 at 20:01:25 from (67.72.98.45):
In Reply to: Farmall 450 Gas Throttle questions posted by Tony_Idaho on March 26, 2012 at 14:42:34:
Follow the linkage forward. At the end of the rod
there is a lever sticking out away from the
engine. This lever has a link attached to it
Part# 362071R1 ROD, engine speed control,
center.
This rod needs to be longer. It can be lengthened
by screwing a thread coupler (hardware store item)
and a short piece of same thread cut off of a
bolt.
To make it 1/2" longer. Or a new one can be
fabricated that is longer. This pushes on the
remaining linkages so the throttle lever at the
governor moves to its limit. (no chance of
overspeeding, it is just metal of the shafts
twisting over time. Checking all link pivots and
rod "L" ends can also tighten it up. Jim
