Re: Help! TD9 doesn't start
Posted by ltf in nc on September 18, 2000 at 08:33:21 from (206.228.214.99):
In Reply to: Help! TD9 doesn't start posted by Loren on September 18, 2000 at 08:09:27:
Pull the plugs and do a quick compression test. If the compression is good then the carb is not set correctly or it is clogged or the choke is not working based on your statement that there is fuel in the bowl.
Post A Followup
: Re: Re: Help! TD9 doesn't start
