Re: 1952 Cub Won't Low Idle
Posted by T_Bone on September 18, 2000 at 10:35:01 from (207.254.52.191):
In Reply to: 1952 Cub Won't Low Idle posted by Dave F. on September 18, 2000 at 09:29:45:
Hello Dave F., You didn't get the idle circuit cleaned as it's still pluged. Your running on the main jets as you can tell buy the 1200rpm.
I like to use Chemtron Berrium B-12 on carbs and injectors as it will disolve any carbon grime and water salts, thats the white looking stuff in the carb ports. You can get it at any auto parts store. I use Pryol break cleaner for precleaning as it's cheaper. The B-12 is a must for cleaning ports out.
T_Bone
Post A Followup
: Re: Re: 1952 Cub Won't Low Idle
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
