Posted by riverbend on March 28, 2012 at 08:10:43 from (74.37.54.212):
When we split the tractor we had the hydraulic lines off and drained the reservoir. The manual says that all that needs to be done is fill the reservoir and work the levers to prime the pump and work the air out of the system. Does this really work ?
The fill plug for the hydraulic reservoir is lower than the pipes running to the pump. The suction side of the pump needs to move a lot of air to get any oil.
Is there a better way to fill the system ?
Is Hy-Tran a suitable replacement for 'Hydra-Touch' or 'Touch Control Fluid' ?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
