Re: refilling 350 hydraulic system ?
Posted by mkirsch on March 28, 2012 at 11:26:09 from (64.80.110.74):
In Reply to: refilling 350 hydraulic system ? posted by riverbend on March 28, 2012 at 08:10:43:
The tractor probably already had HyTran in it.
"Hydra Touch fluid" is what they had before HyTran. It hasn't been available since the early 1960's. Hytran replaced it.
If you haven't run the tractor, drained the lines, or removed the hydraulic pump, the pump will already be primed. Simply fill the reservoir and run it.
