Re: farmall h died on me
Posted by old on March 29, 2012 at 15:29:25 from (209.86.226.19):
In Reply to: farmall h died on me posted by Greg from NC on March 29, 2012 at 15:21:52:
First thing I would do is put the old condenser back in and try it. If it runs good then you got your self the common now days bad condenser right out of the box. If that does not help try the old coil do not take out that condenser. If it still runs bad check you spark from the coil wire to the block and make sure it is a nice blue/white spark that will jump a 1/4 inch gap or more. Shoot you might check your spark first for that matter because if it is good then you need to check the fuel flow out the bottom of the carb drain plug and make sure you have a good steady flow of gas for a few minutes catch the gas to check for dirt etc
