Re: Ensign vaporizer
Posted by Clifford McKinney on March 30, 2012 at 19:33:32 from (99.197.160.57):
In Reply to: Ensign vaporizer posted by Doc Halliday on March 30, 2012 at 06:40:20:
I can make a suggestion that might help: if you find a slightly weaker spring for the Ensign regulator, you may well find that the thicker diaphragm will be able to respond to the vacuum pulses of your 460. I had a similar problem with an Impco on my John Deere 70, and a weaker spring solved the problem. Good Luck.
