The interaction between Classic and Modern is still messed up. None of your posts on this thread have appeared in Classic. YT support has stated that 90% use Classic so your posts might be mostly unread at the moment. This problem may be confined to this thread.
That sandblasting rig was probably the world's largest one-man portable rig ever built. It was way out of OSHA specs running 750 CFM at 120 PSI. I didn't give a damn because I had no employees. I did thousands of those tanks on those turning rolls. They averaged around 35 minutes each. When you work by the square foot, the money comes fast and furious. The truck had an air winch for rotating the tanks. Also had a 45' man-lift, 50hp pressure washer driven from the DT466 crankshaft, a smaller air driven pressure washer., high capacity airless paint setup that could spray coal-tar if need be, and room for my motorcycle that was loaded with the man-lift The big trailer mounted dust collector was rented. Everything was bought new. The environmental regs eventually shut me down. I was in business for 30 years. Long enough. Those 10 degree mid-winter days really got to me after awhile.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
