Re: 826 rear diff drain plug issue
Posted by Janicholson on April 04, 2012 at 18:47:57 from (96.24.99.126):
In Reply to: 826 rear diff drain plug issue posted by Jeff Gibson on April 04, 2012 at 18:36:34:
Drill it out with a 1/4" dia bit. Realize it will get messy at the end of the operation. When oil is found, stop drilling, and use a thin punch to enlarge the hole. Let it drain till it is empty. Then drill it out to 5/8 in stages. use a square, non spiral stud remover to remove the plug. Clean out any chips, rinse and install a new plug. Refill. Jim
