826 rear diff drain plug issue
Posted by Jeff Gibson on April 04, 2012 at 18:36:34 from (166.249.101.218):
First let me thank everyone for insisting on a splitting stand for the clutch job I did on this tractor. I built one from I beam and it made splitting this tractor almost to easy... So back to my new issue I cant get the rear drain plug out to finish draining the trans fluid. The plug is stripped out and it wont budge didn't think you could strip out a square hole but you can. Considering two options, drill out the middle of the plug and tap it for a smaller plug or pull the cover from the lift pump and use a suction machine to remove the fluid. Can I get all the fluid out going thru the lift pump cover? Any other options I haven't considered?
