Re: 350 T/A pressure plate
Posted by 43warhorse on April 05, 2012 at 17:47:03 from (174.254.161.139):
In Reply to: 350 T/A pressure plate posted by riverbend on April 05, 2012 at 08:40:23:
When I adjusted my TA pressure plate:
1. TA lever linkage exteral properly adjusted.
2. TA lever pulled back and latched.
3. Had a 2x4 block holding the clutch pedal all the way down. (Block our tires!)
4. Adjusted the TA pressure plate finger bolts till the pressure plate clears the clutch by .80"-.100" in this position.
5. Lock the adjustment bolts back up.
6. Test tractor.
7. Reinstall cover.
Hope this helps
Cory
