Re: Super A governor problems
Posted by pete 23 on April 05, 2012 at 18:23:00 from (74.32.231.176):
In Reply to: Super A governor problems posted by JBann on April 05, 2012 at 14:19:24:
With the engine running at a moderate idle or low
idle, screw in that bumper until the engine speed
increases. That way you know you are in the range of
the governor controlling the speed. In other words,
you can't really tell if that surge spring is
actually touching the governor arm inside or not.
Did you use the correct spring for replacement.
