Re: International/farmall 544 TA problem~ Please help!
Posted by Janicholson on April 06, 2012 at 08:18:02 from (199.17.6.207):
In Reply to: Re: International/farmall 544 TA problem~ Please help! posted by Tom122047 on April 06, 2012 at 06:19:04:
No. With respect here is the way.
With the tractor shut off, in first gear on concrete or flat hard ground with TA forward (ahead), push on the top of the rear wheels in the forward direction trying to roll the tractor.
If it rolls for 2 feet or more it is in TA reduction meaning the direct clutch is not working and it is in freewheel.
If it rolls 6 inches and stops firmly and cannot be pushed, it is in direct drive, and it is a linkage or TA release bearing issue. Jim
