Re: Bolts for mounting rear wheel weights
Posted by farmallhal on April 06, 2012 at 08:34:01 from (76.4.182.190):
In Reply to: Bolts for mounting rear wheel weights posted by Yooper Farmall on April 06, 2012 at 08:18:35:
Per my Farmall H Parts Catalog it calls for 3/4" X 4 3/4" NC machine bolts for the first set along with lockwashers and hex nuts. For the second set use 3/4" X 3 3/4" NC machine bolts along with the lockwashers and hex nuts. It also calls for regular 1 1//4" OD X 25/32" ID 10 gauge thick washers.
I've never put more then one set on a cast center so don't have anything to add about a spacer between the two sets. Good luck on getting them on the tractor as it will require some mechanical hands or some good friends to help, Hal.
