Bolts for mounting rear wheel weights
Posted by Yooper Farmall on April 06, 2012 at 08:18:35 from (141.210.112.16):
I hope to finish up wire brushing and painting my rear wheel weight this weekend. I'm going to start out with both weights on the land side of the tractor, last year was wetter than usual, but when plowing the land side tire was turning twice as fast as the furrow wheel.
Does anyone know what size/length bolts I need to mount the first weight? I'm thinking I can use hex head bolts for the first weight, then the second weight attaches to the first using square head bolts?
Then I'm thinking about bolting a freshly painted cast iron weight to a freshly painted cast iron wheel center, considering trying to fit in some square radiator/gas tank mounting pads. Anyone try putting rubber between the weight at wheel to save on paint touch ups later?
