I cheat , i use grade five all thread and a half nut and full nut to hold the all thread to the wheel then just start to stack the weights on then when i have enough on a heavy flat washer and a nut that way i can put five or six weights on the land side and four or five on the furrow side as needed some times ya may need two extra on the land side .Even with loaded tires i will run extra weight on both sides and enough on the ft . so that she will just bob a little on a real hard pull on the hills , really hate looking down the exhaust pipe . Rented a farm back years ago that had not been plowed in at least thirty five years and had cattle run on the whole place that long . Now you want to talk about hard plowing . I had a 67 706 gasser that ran well and a set of 710 4x16's behind it with all new iron on the plow set for 8-10 inches deep . when i dropped the plow in the ground i was in forth low with the T/A pulled back and as soon as the plow sunk in it killed the tractor . Oh my this is hard so dropped back to third low with the stick back and tryed again and promptly pulled the fast hitch bundle out from under the tractor shearing off the bolts . Dropped the plow and back to the shop for repairs . Installed new grade 8 bolts and lets try this again added a full rack of 100lbs suitcase weights and figured that was enough , nope she would stand straight up end up hanging two more wheel weights to the ft. and had to drop to second low . a friend came to help me with a 1086 with five bottoms and he could not even get into third gear and keep the ft on the ground with 1200 on the nose . That was the toughest 78 acres i have ever plowed . You could not even touch the moldboards because of the heat .Most of the time the ft of the 706 was a foot or two off the ground .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
