Re: farmall cub w/o spark
Posted by old on April 06, 2012 at 13:40:14 from (209.86.226.40):
In Reply to: farmall cub w/o spark posted by t-bone on April 06, 2012 at 13:06:25:
Both a distributor and a mag have points. The mag will not have a wire going to the battery but the distributor type will have a wire going from a coil to a switch that in turn hooks to a batter. Also a distributor will have a set of clips to remove a cap with 5 wires and then under that cap a rotor and dust cover and under the cover a set of points which is most likely where your problem is
