farmall cub w/o spark
Posted by t-bone on April 06, 2012 at 13:06:25 from (67.142.177.25):
I"ve been unable to start my cub since parking it a couple of
months ago. From what i can tell, i"m getting no spark. The coil
seems to check out ok on the bench with readings between the
terminals about .3 ohms, and 2500 (i think) between the positive
and large wire terminal. This tractor is running on a 12 volt
battery with a negative ground.
How do I tell if I have a magneto vs distributer? Does a magneto
have points and condenser? Also, should the wire from the coil
to the distributer/magneto be connected to the positive post of
the coil, or the negative as I have read about in reference to
older cars.
Any help is appreciated.
