Re: farmall cub w/o spark
Posted by screwstick on April 06, 2012 at 13:53:37 from (174.24.117.103):
In Reply to: farmall cub w/o spark posted by t-bone on April 06, 2012 at 13:06:25:
A Mag will also have clips to remove the cap.
If you have a separate coil connected to the battery, you have a distributor. A Mags coil is internal and you have to remove a cover to access it.
If you are running a 12v battery, the (+) side of the coil connects to the ignition switch, the (-) side to the distributor. Check for voltage at the coil, and spark out of the coil to the block. Check the condition and gap of the points.
