Rub those points with some 320 wet or dry until they're shiny, then see if you have fire to your sparkplugs. If you have fire try starting the engine. If there's no fire use a volt meter or test lite and check for voltage at your coil. With the points open and your ignition switch in the on position you should have voltage on both small terminals on the coil. If there's no voltage at your coil check for voltage at the terminal on your switch that feeds the coil. If you have voltage there replace the wire from the switch to your coil.
If there's no voltage on the terminal on your switch that feeds the coil. Check for voltage feeding your switch. If there's voltage feeding your switch, replace the switch. To bypass your switch run a separate wire from the battery to your coil and then see if the engine will start.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
