If you remove the external linkag from the lever (on the TA clutch throwout bearing visible in the photos), can you put a wrench on it and move the TA Pressure Plate a usable amount? I assume so because the TA lever works. The clutch pedal should move that lever into release about 1.5 inches after the master (engine) clutch releases. It should begin releasing (contacts the TA clutch fingers at the same point the master clutch is dosengaged. It could be that the TA housing ears (now with shims) was machined by someone to compensate for a thin Disc. Not good, but your shims are in the right direction.
The situation may require additional threading on the clutch linkage to the TA lever. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
