Re: 584 ihc hard shifting into reverse
Posted by merle england on April 09, 2012 at 18:38:43 from (207.118.180.234):
In Reply to: Re: 584 ihc hard shifting into reverse posted by jimb2 on April 08, 2012 at 20:32:32:
hi jim found trouble lifted up shifter boot found a short piece of log chain had slid down behind shift lever and bracket removed chain works perfect thanks for help.
merle
